it happens when im driving normal. it'll falll out as the clutch is realesed, but when i put it in the 2nd time, it almost always engages. when i romp on it and shift it hard into 2nd,it'll ALWAYS GO IN. even when im driving normal and i shift it all hard, it usually goes in. the tranny has been run on almost 70% tx7 and the rest ATF.
MABYE THE HIGH QUANTITY OF TX7 IN THE TRANNY IS CAUSING IT TO FALLL OUT OF GEAR?
MABYE THE STOPPER ON MY B&M SHORTTHROW IS OUT OF ADJUSTMENT?
MABYE ITS MY SYNCHRO (god i hope not)
anyways any ideas would be GREATLY appreciated, thanks a bunch
-mike
-mike
amnit: . I can shift it hard and it always goes in too, but if I take my time to shift it will grind. I found out if put it in gear when theres no "load on the tranny", like if I put it in 2nd while the engine is on its way revving down it will grind, but if i put it in 2nd and the rpms isnt going up or going down in between the shifts (if that made sense to you) then 90% of the time it wont grind. I just dont have the time and money to rebuild it, so it will have to do for now
