tranny fluid change/add
  • Thread starter Thread starter 1991vert
  • Start date Start date Jun 13, 2004
1991vert
1,103
Ludlow, MA
Jun 13, 2004
  • Jun 13, 2004
would it be fine to just take off your shifter, add the fluid, and reseal the shifter? mine used to spit fluid out of the speed sensor, but it stopped. i dunno if the fluid is now at the correct level or if its just too low. any input?
T
TheUser
1,859
Springfield, MO
Jun 14, 2004
  • Jun 14, 2004
Have you ever pulled a shifter before? Mine was a PITA to do...stuck to tranny. I think you'd find it easier to pull the plug out of the tranny and stick your finger in there and see if it's up to the correct level. I think there's actually 2 plugs, one to check and one to add...I could be wrong.
R
red92stang
  • Jun 14, 2004
there are two plugs. one is to drain and one is to add. anyone know how much fluid is supposed to be where the shifter is?
HISSIN50
34
129
Jun 14, 2004
  • Jun 14, 2004
i dont think you are gonna get much response; most people drop the fill plug and fill through the shifter until the fluid comes out the fill plug. gonna be hard to eyeball, and not have it be too subjective, i think.
The User is right. pop the fill plug and stick a finger in it.
good luck.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jun 14, 2004
  • Jun 14, 2004
Better yet - pop the fill plug (3/8 socket drive goes right in the plug) and simply add fluid until it starts to run out of the fill hole. That's the correct level - when fluid runs out of the fill hole with the vehicle sitting level -- so you have to put the whole car in the air, not just the front. Most autoparts places sell an inexpensive manual pump that screws to the lubricant container (check out WalMart's Marine section) - you can pump it in with that. You can also pour it in the shifter opening, but you need the fill plug out to tell when it's at the right level. And if you were leaking at the speed sensor and then it stopped, it's probaby because the fluid got low enough that it won't reach the sensor anymore - so you better get some fluid in there, and you probably ought to fix the leak.
1991vert
1,103
Ludlow, MA
Jun 14, 2004
  • Jun 14, 2004
do you think i could put a bead of silicone around the sensor? or is it a must to buy a new one?
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Jun 14, 2004
  • Jun 14, 2004
If it's like the speedo cable attachment on my T-5 the seal is via o-ring. I'd remove it and see if the o-ring is damaged. Replacing it is dirt cheap. A silicone seal is probably only gonna work if you can remove it, clean it up (while the tranny is empty), put it in and seal it, and let it set up before you refill the tranny. If fluid is trying to leak out while you're trying to seal it with silicone, it ain't gonna work.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Resolved 1985 3.8 tbi, Only starts with fluid then runs great
  • broomtail78064
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 28, 2025
AeroCoupe
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
