Tranny help!!!
  • Thread starter Thread starter ilovewomen
  • Start date Start date Dec 13, 2006
I
ilovewomen
  • Dec 13, 2006
My AOD starts and idles perfect in park and neutral, but as soon as i shift into drive or reverse it kills the car. (shuts off)
Any suggestions would greatly be appreciated
ninety15.0
1,336
  • Dec 13, 2006
little more info about the car/mods would be more helpful. I'm not an AOD specialist but i would think it would be something more to do with codes, IAC, or MAF issues more than the actual tranny. i would pull codes and see whats up.
JChalfan
551
Bellevue, WA
Dec 13, 2006
  • Dec 13, 2006
Also I'm not an AOD expert, but if something was physically screwed up inside the trans (torque converter somehow locked up), when the trans was put into gear, it would just stop the engine, like dropping the clutch in a manual with your foot on the break.
I was cracking up about the title of the post "Tranny help!!!" by a guy with a screen name "ilovewomen".
Jeff
85ragtop
BTW, I like dudes.
475
123
NC
Dec 13, 2006
  • Dec 13, 2006
That is very strange. Did it start acting up before this happened?
JChalfan
551
Bellevue, WA
Dec 13, 2006
  • Dec 13, 2006
Good point. Was the car working fine, and then one morning it just started doing this out of the blue?
Jeff
I
ilovewomen
  • Dec 13, 2006
yea jchalfan hit it on the nose, thats what exactly happens, by the way its a full roller 306 with 9:1 ratio nitrous setup
I
ilovewomen
  • Dec 13, 2006
oh, and it was after i laid two 30 foot patches in the reaview
85ragtop
BTW, I like dudes.
475
123
NC
Dec 13, 2006
  • Dec 13, 2006
In my last car I sprayed and never had that happen. I killed two AOD’s but nothing like what you describe. I'll ask around and see if it's happend to any one I know.
I
ilovewomen
  • Dec 13, 2006
thanks ?
76
#10
  • Dec 14, 2006
  • #10
I don't think it's the torque converter or front pump, since both are physically attached the the flywheel (flexplate) and spin whenever the engine is running. Now, if the AOD uses a lockup torque converter, then maybe the converter clutch is'nt releasing and causing this problem. Try raising the vehicle off the ground, put the vehicle in gear (other than park or neutral) with the engine OFF, front wheels chocked if using a floor jack, parking brake released, and try to rotate the driveshaft. It should be difficult to rotate, but should rotate smoothly. If it won't budge, then something may be busted inside the trans or rear end.
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
