tranny leak
  • Thread starter Thread starter denisd
  • Start date Start date Jan 17, 2007
D
denisd
  • Jan 17, 2007
Hello everybody.
I would first like to thank everyone for some great ideas, with your help I have taken care of some small problems. While I was under the car replacing the oil pan gasket (6 cyl. 200) I noticed a leak just above the transmission pan. Their is a nut with a threaded rod thru the center( I think it is a 1\2 nc rod) It is between the bottom of the transmission pan and the floor pan, it looks like it could be a drain plug. Can anyone tell me what this could be and the proper way to fix this leak.
Thanks again Denis
enferno
418
  • Jan 17, 2007
denisd said:
Hello everybody.
Thanks again Denis
that's not a drain plug. that is your band adjustment screw. DO not remove that or turn it unless you know what you are doing. you need to make sure that if you do remove it, that you put it back in the EXACT same number of turns/threads, as it will effect your shift points etc. in your tranny.
if you do pull it, throw some Teflon tape on it, but be mindful of where you put it on the threads - not too far in or the teflon will get into the tranny.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
R
1965 C4 Tranny leaking?
  • Rick1965Coupe
  • Jul 28, 2024
Classic Mustang Specific Tech Aug 7, 2024
Rick1965Coupe
R
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
