tranny mount mayhem
  • Thread starter Thread starter NKau
  • Start date Start date Sep 10, 2004
NKau
1,346
Jefferson, WI
Sep 10, 2004
  • Sep 10, 2004
I've had an ongoing problem trying to figure out why my tranny/engine sit a bit cocked in the car, slightly pushing the shifter handle over to the passenger side of the car, and not allowing the stock bezel/shifter boot to go back on (been this way since I've owned the car).
It appears to me that the actual tranny crossmember or mount itself is causing the location problem. Are either the crossmember or mount offset? Would it be worth maybe trying to flip the tranny mount or crossmember around? I'm really at a loss here; anyone who's had or seen this problem please chime in.
D
DropTopR
175
Warsaw IN
Sep 10, 2004
  • Sep 10, 2004
THere is a right and left to the crossmember. I even think that there is a stamp on it too. Not sure if that would cause a severe offset tho.
NKau
1,346
Jefferson, WI
Sep 10, 2004
  • Sep 10, 2004
That's the thing; the offset isn't really that severe, but just enough to screw up the shifter location enough to where the stock shifter bezel won't fit over the base of the shifter mechanism, and I can't imagine it's good for u-joints or the tranny's tailshaft either. I'll have to take a look and see if I can find some marks on the crossmember. Anyone else?
maverick0716
3,924
Chilliwack, BC, Canada
Sep 10, 2004
  • Sep 10, 2004
I'm pretty sure the bigger bump in the crossmember is supposed to be on the drivers side.
NKau
1,346
Jefferson, WI
Sep 10, 2004
  • Sep 10, 2004
BAM!!!!!! Mine appears to be installed backwards........can anyone confirm this? Thanks a lot guys
NKau
1,346
Jefferson, WI
Sep 10, 2004
  • Sep 10, 2004
Upon further review, it appears the crossmember must be wrong altogether?! It has a bigger hump, but when the crossmember is flipped with the bigger hump to the drivers side, the shifter is pushed even further toward the passenger side; obviously not right. With the crossmember out and the motor mounts loosened, I can get the tranny pushed over to where it should be, but the slots in the crossmember are about 1"+ closer to the passenger side of the car than they should be. I am at a total loss here. I'm afraid to order another crossmember and have the same problem. Is there a company that makes some kind of adjustable crossmember? I'll try and get pics of what's going on to make what I'm talking about a little more clear.
V
v8only
2,378
22
49
Sep 11, 2004
  • Sep 11, 2004
how close does it sit to the pass side??? I'm pretty sure the natural location is offset slightly to the pass side, that's what I've seen in all my stangs so far. I was just under my parts car a couple of days ago. I think, actually the bigger side goes on the pass side. if your boot won't go back on, that is a problem. Something is def not right. You could try oblonging the holes in the trans x member to slide the trans over a little, but that may be a bad fix. I'd look at your engine mounts first to be sure they are not collapsed. It may be your engine that's cocked to one side.
maverick0716
3,924
Sep 11, 2004
  • Sep 11, 2004
I used to have the single hump crossmember and and it has the hump on the drivers side. The hump on the single crossmember is the same size as the big hump on the double crossmember......FWIW
H
helix007
71
  • Sep 11, 2004
check your motor mounts...or better yet buy some new ones.
Silver85TC
130
#10
  • Sep 11, 2004
  • #10
Exactly! The shifter was cocked slightly to the left when I bought my 95 GT. I discovered the motor mount was totally broken on the driver's side causing the whole driveline to tilt slightly to the left. (not to mention alot of vibration while driving!).
I installed new motor mounts and everything now lines up nice and straight.(much smoother too!)
Cheers
NKau
1,346
Jefferson, WI
Sep 11, 2004
#11
  • Sep 11, 2004
  • #11
I'll take a closer look at the motor mounts and see what I can figure out. Thanks everyone.
F
FixrUpr
Clearwater, FL
Jan 19, 2007
#12
  • Jan 19, 2007
  • #12
did you ever figure it out? im having the same problem and I think my motor mounts are still good(about 10,000 miles old, convertable mounts). Let me know
Thanks
NKau
1,346
Jefferson, WI
Jan 19, 2007
#13
  • Jan 19, 2007
  • #13
WOW; thread back from the dead. No, I still don't know exactly what's going on. New motor mounts helped quite a bit, but did not fully take care of the issue. The shifter still does not sit squarely where it is supposed to.
JBeezy53
559
Sacramento, Ca
Jan 19, 2007
#14
  • Jan 19, 2007
  • #14
If I were you guys I get pictures and post them.
FixrUpr - U really brought this thread back!
NKau
1,346
Jefferson, WI
Jan 19, 2007
#15
  • Jan 19, 2007
  • #15
I will do that, but it won't be for a couple weeks; going on vacation until the end of the month.
G
greg251
55
#16
  • Jan 19, 2007
  • #16
Is it a original v8 car or a swap?
NKau
1,346
Jefferson, WI
Jan 19, 2007
#17
  • Jan 19, 2007
  • #17
Mines an original 5.0.
Issue with trans mount not lining up with crossmember slots
  • Bbaker2317
  • Mar 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2025
limp
new edge coolant leak need advice asap
  • 2vBoogs
  • Tuesday at 8:37 PM
1996 - 2004 SN95 Mustang -General/Talk- Thursday at 4:38 PM
Mustang5L5
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
SN95 The Unicorn
  • HANO Motorsports
  • May 18, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
HANO Motorsports
