tranny or converter????
  • Thread starter Thread starter jaidedeye
  • Start date Start date Sep 18, 2004
jaidedeye
627
Goldsboro nc
Sep 18, 2004
  • Sep 18, 2004
ok guy hers my problem.....from a dead stop if i hammer the gas peadal my car hardly spins the tires...it does not hesitate or anything.but if im already rolling in 1st gear @ 20mph and i hit the gas my tires break loose easy as hell. my car pulls really hard from 2800 to redline. could my tranny or converter causing this off the line power loss? also when i let off the gas just before a complete stop my car surges a little.....also my converter will only stall to like 1300 rpm....its supposed to be a 2800
my car runs extremely strong just off the line jump sux....here are my mods
306 ci sportsman block
lightly ported gt-40 iron heads
1.7 roller rockers, HD double valve springs
skat forged crank, trw forged pistons, eagle forged rods
9.5:1 compression
ported stock intake with 1 inch spacer.
FMS F-303 cam
65mm throttle body and spacer
74mm mass air
24lb injectors
walboro 255 fuel pump
MAC cold air intake
MAC 1 5/8 shorty headers
MAC catted H pipe
flowmasters
Tranny:
rebuilt AOD RV shift kit
2800 stall
ponyboy19
1,640
Sep 18, 2004
  • Sep 18, 2004
your cam should be more of a mid/upper range power maker so I'm not sure how much you should expect below 18-2000 rpms or so? You say it pulls hard from 2800 up, I would think that should be about where that cam would make the power in a combination like yours. Also I don't see gears on your list of mods? 3.73-4.10's would help greatly if you don't already have them. You have to remember also that the 1st gear in the aod is a 2.40 vs a 3.35 for the T5 so there is a huge difference there too. A good convertor and gears should drastically help out. You say your converter is stalling at 1300 rpms. is that break stall, if your driving down the road how high will it flash out to? there is a difference between brake stall, true stall, and flash out rpm. Who made your converter? Was the manufacture aware of your combonation and or dyno/power curve. For what it's worth my car is slightly sluggish off the line as well then it will start to get going. Not sure your issue is to far out of the norm?
jaidedeye
627
Goldsboro nc
Sep 18, 2004
  • Sep 18, 2004
sorry..i have 3.73 gears
my converter is a b&m..not the greatest....with my foot on the break and gas the car will start to move at 1300 and the same rpm no matter what i do
ponyboy19
1,640
Sep 18, 2004
  • Sep 18, 2004
yeah B&M is definetly not the greatest IMO. I'm sure there is a lot of performance left in a good converter. If you ever decide to trade up I would email Andre at Edge Racing with a copy of your combination and dyno sheet and see what he thinks. He may suggest a 9.5" "street edge" for your car. http://edgeracingconverters.com/default.htm
rsw007
469
Lexington,SC
Sep 19, 2004
  • Sep 19, 2004
I second edge. see my times 145000mile motor with all the bolt-on goodies. still stock h/c/i
jaidedeye
627
Goldsboro nc
Sep 19, 2004
  • Sep 19, 2004
rsw007.....what stall converter to you have?
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
