  • SN95 4.6L Mustang Tech
tranny problem...help....
  • Thread starter Thread starter romgolferman
  • Start date Start date Nov 30, 2006
R
romgolferman
355
St. Louis
Nov 30, 2006
  • Nov 30, 2006
when u start the car up cold it will go fine for a couple of miles till it starts to warm up. then it just slips like its in neutral. u cant hit the gas very hard or it just revs up and goes nowhere. it is an automatic tranny. it only has 106,000 and hasnt been driven hard at all.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 30, 2006
  • Nov 30, 2006
CHANGE THE FLUID!
R
romgolferman
355
St. Louis
Nov 30, 2006
  • Nov 30, 2006
u really think that may be all it needs? that would be awsome.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 30, 2006
  • Nov 30, 2006
It has probably never been changed which at that mileage is PATHETIC...
Also, it is probably low.
Odds are that lack of fluid changes and letting it get low has in fact damaged the transmission but you may get lucky.
When dealing with automatic transmission problems always do that which is cheapest and easiest first: change the fluid.
Make sure all of it gets flushed including the fluid in the torque converter.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Nov 30, 2006
  • Nov 30, 2006
First...make sure it's full of fluid. While you've got the dipstick check out it's colour and take a sniff. If it a dirty brown and/or smells like someone took a crap in your transmission (literally) then there's a good chance that your forward clutches are burnt. If the fluid is clean and smells fine it could be something as simple as your filter sucking air. Either way, you won't know until you pull it apart.
I’m sorry to say though, that a transmission that works fine initially, then goes south as it warms up sounds like it’s going to need to be overhauled to me. If so….don’t feel so bad. It’ll be a great excuse for you to install a shift kit or an aftermarket toque converter.
R
romgolferman
355
St. Louis
Nov 30, 2006
  • Nov 30, 2006
i just picked the car up a couple of days ago. i know the person that drove it and it was never driven hard. the tranny fluid looks clean but it is also overfull
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 30, 2006
  • Nov 30, 2006
Well, overfilling an auto trans can cause foaming and prevent the car from going into gears. You say it is worse when it warms up. It gets warm, expands, foams, and causes the problem. All you have to do is drain a bit out and you should be good to go
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Nov 30, 2006
  • Nov 30, 2006
i agree with killy if its overfilled drain a bit and it should take care of teh problem
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
9
Electrical F150 ECU in a Foxbody? Idle surge help
  • 93royalblue
  • Sep 10, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
Mustang5L5
