  • SN95 4.6L Mustang Tech
tranny problems
  • Thread starter Thread starter TorqueMonster88
  • Start date Start date Nov 26, 2007
TorqueMonster88
46
  • Nov 26, 2007
in third and fouth gear my tranny makes this whirring sound from 1000 to 1500...any idea of what it could be?? i've ground the gears a couple of times, stupidity really i dont know if that has anything to do with it though
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Nov 26, 2007
  • Nov 26, 2007
Check the fluid level. Could be low.
[BlackDiamond]
119
  • Nov 27, 2007
Mine does the same thing, but I only really started noticing after installing a Steeda Tri-Ax, so I guess this is just normal noise increase because of the nature of it.
TorqueMonster88
46
  • Nov 27, 2007
How do I check the Transmission Fluid?....I checked my manual but its soooooo vague.
merc123
420
North GA
Nov 27, 2007
  • Nov 27, 2007
Left side of the tranny (I think) there is a fill plug. Unscrew it. Fluid should be flush or leaking out of the hole.
Page 8: http://www.bullittarchive.com/1000/1023/TR-3650_Service_Manual.pdf
How-to: http://www.stangpro.com/html/tutorials/other/transfluid.htm
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
