  • SN95 4.6L Mustang Tech
tranny problems
  • Thread starter Thread starter jtb19nh
  • Start date Start date May 20, 2008
jtb19nh
156
May 20, 2008
  • May 20, 2008
The car is an 01 mustang, the tranny makes a whinning sound when in neutral, when you shift into drive it sounds fine. it shifts fine untill around 40 or so mph. then the rpms clime and the car does not go anywhere, could this be anything besides the od band being fried?
old_blue
1,783
282
124
May 21, 2008
  • May 21, 2008
auto?? could be torque converter. how many miles? tranny might need a rebuild.
jtb19nh
156
May 21, 2008
  • May 21, 2008
yes it is an auto, it has 100,000 miles
BobHyatt
378
  • May 21, 2008
Sounds like you have a band that has been toasted and is slipping badly... Or a pump that can't make enough pressure to clamp the band down properly. In either case, it is a rebuild next...
jtb19nh
156
May 21, 2008
  • May 21, 2008
how do you test the tourqe converter?
jtb19nh
156
May 23, 2008
  • May 23, 2008
I just took it for a quick test run. when the car is in N it whines, when you shift into D the whinning stops. i went under and the whining is coming from the front where the torque converter is, first gear also whines till it shifts to second the the whine goes away. when i punch it it goes and does not hesitate. Then if i let off and wait a second then give it a little gas it revs untill i let the rpms come down and eventually catches does this sound like a torque converter or something else?
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Monday at 5:18 AM
manicmechanic007
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
J
Transmission
  • Jraesims
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
JD1964
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
