9 95 stang v6 New Member Oct 11, 2009 23 0 0 Sep 3, 2010 #1 Sep 3, 2010 #1 i bought a 88 gt t-5 5 speed trans, will it work on my 95 302?
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 34 129 Sep 3, 2010 #2 Sep 3, 2010 #2 If you use it with the 88's bell, it will, but the trans/shifter will sit a little bit forward and you might need a DS spacer. If you want to use your SN bell, you need to swap to an SN input shaft on that 88 trans.
revhead347 Apparently my ex-husband made that mistake. 20+ Year Stangneter Jun 14, 2004 9,302 1,645 214 Acworth, GA Sep 3, 2010 #3 Sep 3, 2010 #3 If you go with the fox bellhousing, you will also need a fox clutch fork. Kurt
