The original AOD inspection cover wont just bolt up? I never tried it so I couldnt tell you if it'll work or not. But yeah, do some trimming and drill extra holes. Do whatever you can to close up that hole.
More than likely not. There is a good bit of difference between a flexplate and flywheel in regards to the center section clearances. More than likely it would rub and make a god awful noise if you used the auto block plate on the manual tranny ( I know it does on a 4.6 car )
Technically what you got is for the manual tranny car, it just leaves the lower area of the flywheel exposed
I didnt know if he could just modify the small removeable plate that you take off in order to loosen the torque converter bolts. Not use the original AOD block plate.
