The AOD's are not stronger than the C4s C6s that our big stangs came with.
I did a lot of searching online and elswhere, reading everything I could find about the AOD tranny, and swaping it into our big bodied stangs.
In the end I decided to go with a Tremec 3550 manuel when my C4 died on me.
(Don't buy any tranny from Autozone. They are CRAP!!!!!!!!!!! We got the first one to replace the C4 I toreup becuase I stupidly replaced a valve backwards after a fluid change, and it went like 50 feet before we lost all but one forward gear. The guy at the store took one look at the metal on the magnet we pulled out the pan and ordered me a new one no problem. Except when with in a week of installing the second one it slipped in second gear he couldn't help me, and the remanufacturer wouldn't do didly.)
Anyway, you can swap an AOD into your 72. You will probably be able to reuse your stock crossmember, although you may have to modify it a hair. The other stuff rbohm said about flexplate and the aftermarket throttle valve cable are 100% spot on.
The TV cable issues are why I decided against going with an AOD and renounced my pledge to never own a manuel tranny. You should be able to find more info on the AOD swap on the forum. Search over in the 5.0 section. Just keep in mind that the carb on our cars requires the special TV cable, and proper adjustment to make the AOD work.
