  • SN95 4.6L Mustang Tech
Tranny ??'s
  • Thread starter Thread starter Cantslowdown
  • Start date Start date Oct 22, 2005
Cantslowdown
502
Mt.Home AR!
Oct 22, 2005
  • Oct 22, 2005
Which tranny is stronger the automaitcs are 5 speeds.I know its kind of a crazy comparson but just thinking..
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Oct 22, 2005
  • Oct 22, 2005
I heard that with proper set up, A/T can handle something like 600hp. try that with T-45 or TR3650
Cantslowdown
502
Mt.Home AR!
Oct 22, 2005
  • Oct 22, 2005
I see. How bout just normal driving and all. Fun factor i would guess stick tho..
Hunter-White
162
Jonesboro Arkansas
Oct 23, 2005
  • Oct 23, 2005
Tranny/clutch
Mity..I have been having some either clutch or tranny problems. I think I'm smelling clutch after racing. I am not racing now because I cannot get into third gear with much accelaration. Could My clutch keep me from getting into gear and grinding? Or could my synchronizer be bad? Thanks for your help man
ProCharger GT
153
Cleveland
Oct 23, 2005
  • Oct 23, 2005
my old setup is in my sig - with a built auto tranny. i have no idea the #'s the new setup will put out but it will be significantly higher than those listed below.
mity2
Jul 24, 2003
2,872
StateCollege PA
Oct 23, 2005
  • Oct 23, 2005
I don't know Hunter. When my trans went(or so i thought), I can shift in to any gear as long as engine arn't running. But once car is started, it will not go in to any gear, I can start car while its in gear, but as soon as i started to let clutch out, engine would make all sorts of noice, as if i'm trying to move the car while E-brake is firmly on.
Turned out the it wasn't tranny at all. Instead, i blew clutch disk apart. There was no friction material left.
SO as far as your probrem goes, I don't know your driving habit of manual trans, but I think smelling burnt clutch after race is somewhat normal, if your not letting clutch in&out fast enought, or not matching RPM. Or clutch disk is on its way out. Your clutch might be worn(How many miles on it?), or worped, or sould be damaged. U can check that by taking out clutchfork cober, and inspect inside of it. If you see fragment(not powdred, or very small peice, but chunks) of friction material, then i would look i to maybe check clutch(as i sould have. i choose to ignore that, and bought extra trans I didn't need)
But if you can still drive the car normaly, meaning no racing, then i'm leaning towrds bad synchro. when you said
By that, i'm assuming you can get it in 3rd while not racing, under normal driving condition without an issue. classic pymptom of worn synchronizer. If thats the case, then you answered your own question.
that or you meesed up shift fork, which is famous for being weakest link of T-45 seriese transmission
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Oct 23, 2005
  • Oct 23, 2005
the 4R70W is stronger than the 5spds stock to stock.
Cantslowdown
502
Mt.Home AR!
Oct 23, 2005
  • Oct 23, 2005
I see I see. Nice to know since I am looking at a mint 98 and a 99 Cobra. Yes I know the 98 is slow and would take alot of work to get in the same time as a stock 99 cobra.
stangGT97
1,299
Boston area, MA
Oct 23, 2005
  • Oct 23, 2005
not true, there isnt a huge difference between the 98/99 performance-wise, especially if the 99 hasnt been taken in for the numerous recalls on it. When Ford redesigned the intake, they messed up the port sizes and the car's claimed 320 hp is really significantly less as a result. Couple that with the heavier IRS and your 98 snake should run all over it.
Cantslowdown
502
Mt.Home AR!
Oct 23, 2005
#10
  • Oct 23, 2005
  • #10
Talking about a 98 GT automatic my bad guys
Cantslowdown
502
Mt.Home AR!
Oct 23, 2005
#11
  • Oct 23, 2005
  • #11
P
rear Impact absorbers.
  • Praetorious
  • May 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2026
Praetorious
P
G
79 steering rack problems
  • garyrc
  • Mar 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
AeroCoupe
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
Fox Prepping a '91 to start after 5 years sitting?
  • 331strokerGT
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 16, 2026
limp
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
