tranny shake
  • Thread starter Thread starter TTMustang
  • Start date Start date Aug 5, 2004
T
TTMustang
  • Aug 5, 2004
this past winter i did an AOD to a T-5 swap on my '90 GT and it went fairly well, the only problem i had was when i would hit within the 70-80mph range i would get a nasty vibration from the tranny, it doesn't shake the rest of the car like unballanced tires just the stick. if anyone can help me i would really appreciate it. thanks
Stang8URMPRT
1,100
Daytona Beach, FL
Aug 5, 2004
  • Aug 5, 2004
I've had the same problem before... It was caused by the tranny to bellhousing bolts being loose.
Nick
N
Nosfurato
296
Indiana
Aug 5, 2004
  • Aug 5, 2004
Also, check the U-joints.. and crossmember bushings.
M
Mhypertext
30
Joplin MO
Aug 5, 2004
  • Aug 5, 2004
its could be a bad bearing on the input shaft of the tranny
millhouse
1,985
Simpsonville, SC
Aug 5, 2004
  • Aug 5, 2004
A majority of people that have had this problem fix it by replacing either the u-joints, the driveshaft of both.
I replaced both with a 99 v6 driveshaft (free) and it fixed my problems.
T
TTMustang
  • Aug 5, 2004
thanks a lot ill check these things and hopefully it will be fixed
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
Progress Thread H/C Swap Problems/Ideas
  • sav22rem22
  • Mar 31, 2024
2K
Fox 5.0 Mustang Tech Sep 10, 2024
AeroCoupe
