Tranny Solenoid Voltages?
BlackVert
5,589
9
98
Bethesda, MD
It appears that my #1 shift solenoid (SS1) it not coming on, which is causing my tranny to not shift into 1st or 4th, so I am thinking about rigging up a little toggle switch to try controlling it externally.
Do those solenoids take a 12v source, and if so, what fuse can I tap into to give it the juice it needs? Or I suppose I could tap straight to the battery and put a 10A (or whatever the correct size is) fuse in line with it ...
What if I hooked it up to a potentiometer?
This stuff would probably either take atraight 12V or a 5V signal. Measure the other solenoids to see what kind of voltage is bing applied then you can apply the same.
I used to to this on a mopar trans to get the OD to come on.
