Tranny Swap ?'s
I did a search and found nothing that said it can be done. I have the T5 from a Turbo Coupe with hydro clutch, and I'm looking for info on how to convert my a4ld lx to a T5 hydro clutch. More so curious to see what is needed and the work involved with the swap. I have seen a FAQ and how to do the cable assembly. So my big question is does anyone know of such pages for the hydro clutch set up?
do you have the pedal assembly and Clutch master cyl from the turbo coupe as well? T5 swapping is common and relitively simple but the hydro clutch makes it tougher. If you have the pedals and Clutch master from the TC it should bolt right up. Otherwise i would locate a Bell housing from a cable clutch mustang, and a mustang pedal assembly. Thats the easiest way. the TC tranny will work fine with either bell housing but you will need a mustang t5 driveshaft.
Dr.
