  • 1994 - 1995 Specific Tech
trans assembly Q
  • Thread starter Thread starter Black70Fastback
  • Start date Start date Feb 28, 2004
Black70Fastback
319
Dyer, IN
Feb 28, 2004
  • Feb 28, 2004
the slider part of the 3rd/4th synchro assembly has more of a bevel on one side than the other in my t5. i forgot which side faces the front of the transmission. please help. im very close to putting the thing together
mytight95
2,605
Dothan,Al
Feb 28, 2004
  • Feb 28, 2004
the bevil goes to the imput shaft end of the case, i have a rebuild manual in adobe format i could send you if you want to just check things out.
my e-mail is mytight95@msn.com
Black70Fastback
319
Dyer, IN
Feb 29, 2004
  • Feb 29, 2004
thanks, thats what i did. its all together now except the tail shaft housing. i didnt get the speed gears yet. i already had a manual downloaded from tremec but the picture was crappy and it didnt say how to put it on other than "the same way it came off."
mytight95
2,605
Dothan,Al
Feb 29, 2004
  • Feb 29, 2004
cool man, are you changing the drive gear on the output shaft for gears or something, if you don't have a stock gear i could send you one instead of buying one. But you can get whatever you need at a local tranny parts store, they will probably have what you need in stock
Black70Fastback
319
Dyer, IN
Feb 29, 2004
  • Feb 29, 2004
we're putting 3.73s in it almost immediately after the trans gets put in. i drove all over saterday and most places said they could order it. others said they wont even bother. how much does the drive gear usually cost? the last time i bought a driven, i think it was like ten bucks.
mytight95
2,605
Dothan,Al
Feb 29, 2004
  • Feb 29, 2004
the drive gears are like 10$, have you went to the hanlon motorsports speedo calculation page yet it will tell you what drive and driven gears to get. I changed my drive gear to a black 10 tooth gear and my driven was a 19 tooth gear which is what i needed so i left it alone
jason
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
T
2001 GT 4.6 V8 weak crank no start.
  • The-Bamboo-Farmer
  • Nov 12, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 13, 2025
The-Bamboo-Farmer
T
