  • SN95 4.6L Mustang Tech
Trans or shifter?
  • Thread starter Thread starter the_rooster
  • Start date Start date Aug 8, 2008
the_rooster
32
philadelphia pa
Aug 8, 2008
  • Aug 8, 2008
I havent been driving my 96gt 5spd for a while due to a messed up hand, but when i drove it in this mourning i started having a problem. When i first started driving it was hard to get into 2nd and 3rd but it wasnt too bad, i would have to force it a tiny bit and it wasnt every time. After driving on the highway for about 20min i got close to my work and hit some lights, so i'm going to put it into 1st and i would have to force it, i had to double clutch it into 2nd and 3rd but not 4th or 5th for the first light, the second light wasn't too bad and then again for the last light. Any ideas? Thanks in advance for any help
BobHyatt
378
  • Aug 8, 2008
one thing I have seen twice in the last two years or so on two different mustangs. If you get under the car, look at the side of the tranny about 1/2 way up and 1/2 way back on the driver's side. there is a round-head bolt with a torx opening. This bolt is the actual pivot point inside the transmission for moving the shift mechanism around. It should be flush against the side of the tranny case. If it is backed out significantly, it needs to be tightened back up. But it is not so simple and you need two people. One underneath with a ratchet with the correct sized torx bit, and one in the car with the transmission in neutral moving the shifter back and forth. the person underneath has to carefully screw the bolt in using little force. If it binds, back off just a bit and get the person to try to shift between 1-2 or 2-3 or whatever. And as the shifter is moved, the bolt will go in without excessive force. Once it is all the way in, torque it down that last 1/16th turn or whatever.
No guarantee this is the problem, but it happened to ours. Started off not going into reverse, although 1-5 worked fine. We continued going to the strip, and occasionally driving it around town when we could avoid situations requiring reverse. Then it started getting balky at going into 1/2, although 3-4-5 were OK. I then noticed that if I first shifted into 5, and tried to shift into R (which would not happen) then I could get it into 1st every time. We took the thing apart thinking it was something major, but after removing the tailshaft and the bell housing, we discovered that the problem was just the loose pivot bolt and it has worked perfectly ever since...
We bought it used, and could only conclude that maybe someone wanted to change the tranny fluid (it had synthetic when we got it we discovered) and they might have initially thought that was the fill point and figured it out after a bit...
the_rooster
32
philadelphia pa
Aug 10, 2008
  • Aug 10, 2008
I'll take a look at it but that doent really explain why it wil only do it when it gets hot. I'll take a look thanks
Silverstang02GT
60
Ft. Myers FL
Aug 10, 2008
  • Aug 10, 2008
It could be the Clutch or pressure plate. If the pressure plate is warped it may get worse as the car heats up. I don't think it would be the shifter. If the transmission was bad it seems like it would shift bad from the start. When my sencros went bad in my tranny it shifted hard when the car was cold and warmed up.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Drivetrain 5th Gear Ratio
  • PonyGTrider
  • Dec 8, 2025
2K
Fox 5.0 Mustang Tech Dec 31, 2025
Qtrhrse23
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
