Trans still leaking!
!white89lx!
32
Alabama
ok so ive checked all the nuts and bolts on the tranny but its still leaking??
the trans fluid drops on the mid pipe on the drivers side
it creates bad smoke at stop lights and smells bad
im afraid that all the tranny fluid is gonna leak out and cause the trans to sieze
any one know what it could be?
We assume this is an auto?
One drop of fluid on a hot exhaust makes plumes of smoke. If you ever have a turbo and lose a shaft seal, you'll see what I mean.
Has anything been done to the trans lately? If so, was a good gasket (metal over rubber, with ferrules in the bolt holes) used? Were the rails on the pan completely flat?
I would clean the trans up and see if you can note where the fluid comes from exactly.
Good luck.
check the speedo cable, right below where it connects to the trans. Put some silicone or gasket sealer right where the metal is crimped to the rubber sheath. Most likely that connection has separated a little and it's letting some trans fluid leak down the cable where it gets caught by the wind and then sprays down on the mid pipe, or drips on the exhaust while stationary.
