transmission fluid level
jdogg1583
10
Im currently installing a short throw shifter into my 2002 gt. I drained the fluid and then i put about 3.6 quarts of new fluid back in. However the fluid does not come up into the shifter part and I was wondering if it was supposed to. Does anyone know if there is supposed to be fluid up where the shifter attaches to the transmission.
Also, does it matter if there is a little of the old fluid left in there because the new kind is different then the old.
Any help would be greatly appreciated. Thanks.
what does tsb stand for?
ok so since the fluid isn't supposed to be higher than the fill hole there probably isn't supposed to be any fluid in the shifter part of it right?
You will notice tranny fluid in the shifter housing. The new mustangs use 3 to 3.2 Liters of regular (non synthetic) dexron III ATF. That's what I used when I changed my clutch.
From all the threads I read, the synthetic is too slippery for the synchros to grab so tremic switch to regular fluid. They also decreased the quantity from 3.8L to (3.0L to 3.2).
right no fluid in shifter part....leave fill plug out and pour it in the shifter area till you hear it leaking out the drain hole below.
