Transmission
  • Thread starter Thread starter Kealani
  • Start date Start date Jun 17, 2019
K
Kealani
9
Lakeside, Oregon
Jun 17, 2019
  • Jun 17, 2019
Hi need some help here. I have. 2000 3.8L T5 manual transmission that either I have rebuilt or I found one it’s from a 1998 manual T5 Mustang. Will that fit in mine as well work I’m mine?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 17, 2019
  • Jun 17, 2019
Yes it will "bolt up". No. It won't work as well.
The 1996-1998 model year uses a VSS contact style speed sensor. The VSS sensor is driven by a worm gear on the output shaft.
The 1999-2004 model year uses an OSS non-contact style speed sensor.
The output of a VSS sensor is NOT compatible to the signal type of an OSS sensor. The wiring is different. The type of sensor used needs to match what the PCM is expecting.
Here's is some more information that may help you to understand the difference between the VSS and OSS sensor.
T-45 Tail Shaft Swap
Please feel free to hit me up with any corrections I have overlooked... This write up is for the T-45 tail shaft swap. I had to change my tail shaft due to the magnetic speed sensor (found in the 99+ models) as appose to the gear driven sensor (96-98 models). Car getting the tail shaft swap...
www.allfordmustangs.com
Try searching car-part.com for salvage yards in your area that may have units that will interchange without having to re-configure.
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
K
2000 3.8 v6
  • Kinglife2121
  • Nov 2, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 2, 2025
Kinglife2121
K
I
2000 GT Mustang - Transmission Cooler to Radiator o-rings
  • Iwarrior
  • Oct 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 4, 2025
Iwarrior
I
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
