  • 1994 - 1995 Specific Tech
Tremec troubles
  • Thread starter Thread starter jorge.pena
  • Start date Start date Jan 13, 2006
jorge.pena
30
San Antonio,TX
Jan 13, 2006
  • Jan 13, 2006
I'm running a tremec 3550 on my car, and from day 1 when you put it in 5th gear you get all this fricking gear noise coming into the cabin. Everybody told me that tremecs are noisy but this is ridiculous. the other 4 gears make some noise (whine) specially at WOT but that 5th sounds like an old mack truck. Took it to a couple different shops and they told me that tremecs are just like that, you just got to live with it. I don't buy it! it's this constant gear meshing noise that just bothers the crap out of me, the only time it quiets down is when you get off the gas. Any suggestions would be appreciated.
Joes95GT
3,132
Delaware
Jan 13, 2006
  • Jan 13, 2006
Reasons for gear noise (that I can think of) are the following:
1) Low fluid level.
2) Bent mainshaft/countershaft.
I'm unsure of the gear "orientation" of Tremec's but I still think that the above principal holds true (number 2).
Joe
SQUEEZE&STROKE
SOUTHERN CA
Jan 13, 2006
  • Jan 13, 2006
Does it have the stock bellhousing...If not did you index the bellhousing...this could result in a misaligned input shaft POSSIBLY, and only possibly causing your problem. Just a suggestion, no claim to accuracy
M
miley_stang
58
Tampa FL Area
Jan 13, 2006
  • Jan 13, 2006
If his transmission was out of alignment, the noise wouldn't change with different gears.
What kind of fluid are you running? I heard if you don't use synchromesh fluid, it will wine alot more. Also, is your shifter isolator still installed between the handle and shifter base?
broken_joke
138
carriere, ms
Jan 14, 2006
  • Jan 14, 2006
are you using gm snycromesh fluid?
jorge.pena
30
San Antonio,TX
Jan 15, 2006
  • Jan 15, 2006
Yes I'm running Syncromesh and no the Pro5.0 shifter has no isolator, as far as the bell housing goes I'm pretty sure it's the stock piece. And it better not be a bent shaft, it's a new tranny.
sc95gt
23
  • Jan 15, 2006
You might try a set of these gaskets - reduced the noise from my 3550 by half - can actually drive the car now without the radio up!
http://www.stangshiftergaskets.com/
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jan 15, 2006
  • Jan 15, 2006
Tremec's are noisier. Mine will whine and howl in gear and its perfectly fine. Goes into gear like butter @ 6,700 rpm
HISSIN50
34
129
Jan 15, 2006
  • Jan 15, 2006
NO_RICE is having similar issues - perhaps compare notes with him if you want. He has removed the trans recently to inspect things and did not find much too revealing as I recall.........
jorge.pena
30
San Antonio,TX
Jan 15, 2006
#10
  • Jan 15, 2006
  • #10
to sc95gt
I ordered a set of those gaskets, hopefully they'll quiet down the racket.
And man do I know what you mean about the radio being turned up!
jorge.pena
30
San Antonio,TX
Jan 15, 2006
#11
  • Jan 15, 2006
  • #11
Hey, broken_joke, how's that intake working for you. They look like a great set up for a blower, but I always wondered how they run if theyr'e just sucking wind, specially at the bottom end of the power band.
broken_joke
138
carriere, ms
Jan 15, 2006
#12
  • Jan 15, 2006
  • #12
i have no new numbers to compare with vs my old trick flow r intake. but just from articles i have read about the victor jr on carb'd applications the avgerage power is higher. i think it pushes the band higher were it makes peak power. i like it and the car runs strong. this article kinda has a shootout with various intakes and the spyder does well.
http://mustang50magazine.com/techarticles/93438/index.html
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
