Tri-state cylinder heads
well like its like 88 mouse said i have run 2 different sets of these heads and have had great luck with them , i would recomend these heads to nebody wanting a cheaper head, these heads are a rhs / dart pro 1 knock off head and will out flow afr 185s and edlebrock anyday
You are not serious, are you? What are you compairing, a 210 head to a 185?
Tri state heads are simply a pro-comp head with a bit of bowl cleanup and cnc done.
To get them to perform to the standards of a set of TFS or AFR's will require upgraded hardware and cnc work...there is no way around it.
