Tri Y headers/ starter clearance
  • Thread starter Thread starter Bluepiper
  • Start date Start date Jan 29, 2011
Bluepiper
11
Central California
Jan 29, 2011
  • Jan 29, 2011
About 8 years ago I installed a set of new Tri-Y headers on my '66 289 engine. It has now come time to replace the starter. When I pull the starter out I noticed a huge "dimple" on the starter where it interfered with the header. The starter worked great for 8 years, but now if I go to replace the starter I will have a problem installing it. It seems that when I tightened the header on that side it crushed a portion of the starter where the actuator cover is. The header sealed against the gasket properly. Is this a common problem? Is there another smaller starter I can use without going to the expense of the small hi torque starters ($200.+). Again, it is the small cover on the top of the starter that is hitting. It is a 289 w/ 3 sp. manual trans. Thanks.
O
other_shoe
313
  • Jan 29, 2011
On my 67 it is a tight fit and hard as heck to get in and out, but I made it work. The last time I replaced the starter, I noticed that there was variance between the actuator cover on the old unit and the new one. Looking at the pictures on the Autozone website it appears that there are different covers for the auto and manual, which makes sense given the other differences between those starters. I wouldn't be surprised if some remanufactured starters had a universal, roomier cover that protruded further. I heartily recommend taking it out and comparing what's in the car to replacements at a couple of part shops. That is what finally let me figure out the manufacturing flaw that made mine produce a squealing sound.
hipo_p51
199
  • Jan 30, 2011
I remember installing a starter with tri-y's on a 289 years ago. tight fit and patience is required.
rbohm
6,698
550
204
tucson,az
Jan 30, 2011
  • Jan 30, 2011
you can always swap over to a late model mini starter in your stang. you just need a minor bit of rewiring that isnt difficult to do at all.
P
Pony66
124
  • Jan 31, 2011
IF you have the 165 tooth flywheel and bell, it sits out about 1/2 inch more than the 157 tooth FW. Also when I replaced my starter this summer, the stores have the Auto and Manual part #s mixed. So be sure to ask for an Automatic starter.
I couldnt get the Manual starter to fit my 66 with T-5. I read about the mix on this site. Traded for an Auto starter and it fit perfect in seconds.
Bluepiper
11
Central California
Jan 31, 2011
  • Jan 31, 2011
"Auto Starter??? But I have a 3 speed Manual trans. I think you may have miss read my original post.
Thanks
F
fastaggie
21
Houston
Jan 31, 2011
  • Jan 31, 2011
Thanks
Bluepiper, you are misreading Pony66's post. He is saying (I think) that the auto supply place where you bought the starter may be one of those that has the numbers reversed on the auto vs standard transmissions and therefore when you bought your replacement they may have given you the wrong one. He is suggesting you take it back and ask for a starter for an auto and would receive the correct part. Or, just take it back and ask to compare it to the one for an auto and see if it is smaller or larger.
Bluepiper
11
Central California
Jan 31, 2011
  • Jan 31, 2011
Got it....thanks. I will compare them at the parts store.
Alohastang
38
Honolulu
Feb 2, 2011
  • Feb 2, 2011
Starter Clearance
Install a High Torque Starter - the Starter Housing is much "smaller" than the original bulky unit.
NasaGT
1,993
Virginia
Feb 3, 2011
#10
  • Feb 3, 2011
  • #10
+1, the late model mini starters are much smaller than the originals.
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
Exhaust 1 3/4” Long Tubes on a Fox Body AOD – Easiest route?
  • 5.0 Mike
  • Mar 19, 2025
2K
Fox 5.0 Mustang Tech Mar 21, 2025
5.0 Mike
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
Starters suck. So does the aftermarket!
  • Blue Thunder
  • Apr 30, 2024
5K
1974 - 1978 Mustang II Talk & Tech May 13, 2024
Blue Thunder
