tri-y install
  • Thread starter Thread starter 1fstpony
  • Start date Start date Jun 2, 2005
1fstpony
76
Iowa
Jun 2, 2005
  • Jun 2, 2005
I have a 66 Fastback that I'm installing a new endine in and was wondering if I should put the tri-y's on before or after the install.The engine bay also has fresh pai and I'm planning to use blankets on the engine bay sides for the install, (don't tell the wife that I'm using her blankets,you guy's know what I mean)but I'm not sure of the best way to do this. Thanks
iskwezm
4,159
20
79
Rowland Heights,California
Jun 2, 2005
  • Jun 2, 2005
From what i've experienced with mine,there is no way in hell to get the motor in with the headers on without sratching something.Youll just have to fight with them after.
Pathfinder65
142
Ottawa, Canada
Jun 2, 2005
  • Jun 2, 2005
My tri-y's have been in and out a couple of times. Not difficult at all if you feed them up through the underside.
Dave
1fstpony
76
Iowa
Jun 2, 2005
  • Jun 2, 2005
thanks guys
XXBULLETSXX
301
Kannapolis, NC
Jun 2, 2005
  • Jun 2, 2005
My Tri-Y's went on after and from the bottom. I found for my install the it was easy to put on duct tape on the sides of the pipes(not all the way around the pipe, just the sides that will hit the engine well) and then it's pretty easy to peel it back off. As long as you remove the tape within a couple of hours then all the adheasive should come off with the tape. If not, well just wake up your pony and burn it off
Otherwise it's actually pretty easy and even easier if you get a friend to help you from up top.
R
ron67fb
1,117
SF Bay area, CA
Jun 2, 2005
  • Jun 2, 2005
I recall an old magazine article where they wrapped the headers with garbage bags during the install. Just rip them off when you're done.
Pathfinder65
142
Ottawa, Canada
Jun 3, 2005
  • Jun 3, 2005
Easy to do yourself as well. Just have a short length of bungee chord handy. Feed them up carefully from the bottom and then use the bungee wrapped around the bottom of the header near the collector. Hook it onto something to hold the header from falling out while you move up top and bolt them in place.
Dave
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
J
Headers
  • Joe Johnston
  • Sep 19, 2024
1965 - 1973 Classic Mustangs -General/Talk- Sep 21, 2024
Joe Johnston
J
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 26, 2025
