trick flow head???
what trick flow head is this???
i forgot the serial# ( it was SN something something 707 i *think*)
but it doesnt say trick flow on it. when i called summit they said it was trick flow twisted wedge track heat heads
but hears the deal
it has pedastel rockers and a non adjustable valve train.
the head is aluminum, and definitely not a gt40 head.
So what model head is this???? any info is much appreciated.
thanks much-
what head is it
Your head is a older style of the Pedestal mounted trick flow head,Trick flow made that head several years ago,but have sense did away with it because of some valve train trouble they ran into( push rods need to be longer) and decided to use adjustable only.
most likely the heads have the old style valve guides as well which will need to be changed .no big deal you can order the new bronze ones through summit racing and have a local shop do them and as far as the Pedestal mount you should have the heads drilled for 3/8 studs .The rest of the head is the same as today's trick flow good luck:nice:
