I just dropped the engine in the car. Found a few issues.
First off the accessory bracket bolt doesn't fit one hole in the front of the heads. Is there some kind of adapter I can get? The hole looks like a 5/8 and I have a 7/16 bolt. I checked locally and I couldn't find anything.
Also, did you plug the smog hole on the back of the heads? I looked in there, the hole goes all the way through to the front, but I see NO openings for smog exhaust. So what would be the point of capping the back? It should help keep heat from being trapped in the head right?
