Trick Flow Intake Gaskets
Fel Pro Part Number MS93334, it's a kit for that type of install. The manifold should have come with a gasket for the upper to lower. I made one for the adapter to upper, and had a new one for the TB to adapter. that FelPRo kit is available at autozone, advance, all those places. Get yourself some new vacuum line to replace the 10 year old stuff on there. I was also one plug short, found one at Lowe's in the plumbing section though, works like a champ. Good Luck man, later
Make your own elbow gasket out of gasket material, which is available at Advance. You can use your stock throttle body, assuming of course, you use the elbow adapter.
Vacuum lines are available at your local Ford dealership, and are probably fairly priced.
Joe
what ain't fairly priced for our cars? I just want it back on the road its been in a barn for like a year all torn apart i took my intake down to sit it inside the car so it won't get messed up and its starting to like mildew inside i was not very happy to notice that maybe by the end of the month i'll have it running again i got the idea of polishing stuff from GT1105 and its set me back i don't have the patience for that stuff see if i listen to him again lol
