Trick Flow Intake Manifold to Fuel Injector Clearance
JasinC19
What hole is this!?!
Jun 7, 2011
312
Does anyone have a Trick Flow Street Burner/Track Heat intake manifold installed in conjunction with EV6 uscar injectors with the jetronic adapters installed? Stock fuel rail.
I'm trying to figure out if the top of the injector connectors will clear the upper intake manifold or not. I had issues with the BBK aluminum fuel rail without spacer.
Thanks!
Well I just so happen to have one installed! The problem is with the vacuum line block under the driver side. It's extremely close to the injector connectors.
