Trick Flow Lower Intake Problem
BBrinks
519
Woodridge, IL
I took out my lower intake manifold because I thought the head gaskets were leaking: http://forums.stangnet.com/showthread.php?t=633833 I cleaned off the gaskets on the lower manifold and the 4 corner ports are pretty pitted.
Do you think that it's safe to put the gaskets back on like it is right now, or should I just get a new lower? I was thinking of putting a little sealant to try and fill the gaps a little, but wasn't sure how effective it would be.
Mine are a hell of a lot worse than that and I've never even given it a thought. I use a quick dab of RTV around the water passages before I put the gasket on and I've never had a problem.
