Trick Flow oil fill
  • Thread starter Thread starter stang_hp
  • Start date Start date Mar 19, 2007
stang_hp
62
cartersville Ga.
Mar 19, 2007
  • Mar 19, 2007
I just purchased the trick flow H/C/I, where do I put the oil fill kit? the valve cover does'nt have provisions (knock outs) for it.
LB0193
171
IL
Mar 19, 2007
  • Mar 19, 2007
You have to drill a hole in the valve cover yourself
stang_hp
62
cartersville Ga.
Mar 19, 2007
  • Mar 19, 2007
what is the hole for on the back of th intake?
Sicarius428
2,085
Mar 19, 2007
  • Mar 19, 2007
I used a rubber band and found the spot between the pairs of rockers. That way you have less chance of oil being squirted up into the oil fill back into the intake. Then I used a 1 1/8th(don't quote me on that) wood drill(it was a lot cheaper than a real one) and put a hole there. Used some rtv on the gromet and it was done.
Kevin
Sicarius428
2,085
Mar 19, 2007
  • Mar 19, 2007
Hole in the back of the intake is for a PVC valve.
Kevin
stang_hp
62
cartersville Ga.
Mar 19, 2007
  • Mar 19, 2007
thanks for the info!
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Mar 19, 2007
  • Mar 19, 2007
drill a hole and install a gromet and use a filter type breather cap that pulls out to fill oil
T
Terdfurgason
31
Olympia, WA
Sep 22, 2007
  • Sep 22, 2007
DOnt make my same mistake!
I drilled a hole in the front corner of the valve cover, nice clean hole. Put the valve cover on the car to test the fit and it was right above the rocker, wouldve punched the oil fill tube right out, lol. I sealed it and redrilled a hole at the tallest point towards the front of the valve cover.
cobradvm
245
Woodinville, WA
Sep 23, 2007
  • Sep 23, 2007
Send those fugly things back to Summit, get a credit for them, and then get these from AFM - much better quality and a good price...
http://www.andersonfordmotorsport.com/
P/N AF-6582-A1
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
