Trick Flow oil fill
I used a rubber band and found the spot between the pairs of rockers. That way you have less chance of oil being squirted up into the oil fill back into the intake. Then I used a 1 1/8th(don't quote me on that) wood drill(it was a lot cheaper than a real one) and put a hole there. Used some rtv on the gromet and it was done.
Kevin
DOnt make my same mistake!
I drilled a hole in the front corner of the valve cover, nice clean hole. Put the valve cover on the car to test the fit and it was right above the rocker, wouldve punched the oil fill tube right out, lol. I sealed it and redrilled a hole at the tallest point towards the front of the valve cover.
