trick flow or edelbrock
  • Thread starter Thread starter spchernandez
  • Start date Start date Feb 22, 2006
spchernandez
28
  • Feb 22, 2006
well guys i need help on decision, right now i have tfs TW with o-ring grooves, and my friend is selling his edelbrock rpm with o-ring grooves too. they are the same valve sizes for intake and exhaust. just which one will put out more power or is it going to be the same. they have about 1,300 miles
R
Redrooster
73
  • Feb 22, 2006
Stick with the trick flows they are a better head. Better flow #'s and better potential. edlebrocks are good, just not as good. the TW out flow them by 30 cfm at .500 lift out of the box.
Sicarius428
2,085
Feb 22, 2006
  • Feb 22, 2006
Stick with the Trick Flows. Edelbrocks are a good head but the TFS do flow better. If they have the same size valves as the TFS, you may have to check the valve to piston clearance. TFS changed the angle on their valves to be able to fit the huge valve on a stock bottom end. I don't know if edelbrock took the same precaution.
Kevin
I
IntenseBlue
946
  • Feb 22, 2006
Trick Flow heads perform better out of the box and ported. The valve locations of the heads make these the only heads that can run a 2.02 valve on stock 87-95 5.0pistons.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
