Engine Trick Flow Street Heat Top End Kit
ace940
87
hi all, i was wondering if anyone on here has ever used the trick flow top end kit. and if you did does it actually bring it up to 350hp. or is that just a label. if you did buy it was it worth the money or would you be better off to put on an ebay turbo kit and run like 12psi. thanks
but what im wondering is is it worth twice the money for the top end kit or is it better to get a 1700 dollar ebay turbo kit off of ebay with everything. i know that with the turbo kit its possible to make a lot more power but its different than n/a.
The Trick Flow top end kit is the best available in my opinion as well. You can make more money with the turbo kit, but don't expect it to be $1700 out the door. $1700 is going to buy an extremely cheap turbo kit and you get what you pay for. There will be a lot of money for supporting mods that you are going to need to spend either way, but more so for the turbo kit.
Kurt
