• Community Forums
  • The Welcome Wagon
Trick Flow Top End Kit Help. High Timing
  • Thread starter Thread starter aotrucker
  • Start date Start date Feb 8, 2016
A
aotrucker
  • Feb 8, 2016
Hello I am new on here. I just installed trick flow top end kit on my 92 fox 5.0. I want to get it dyno'd but why is my timing at 38° to make it even run right. If I advance it more it stalls and won't start. If I start retarding it runs like total crap (misfire, ect) . I know my timing chain marks are lined up right when I put it back together. Please help!
Farrell5.0
Not sure what "DP" means, but know's he likes it!
353
299
104
Vancouver, WA
Feb 8, 2016
  • Feb 8, 2016
Did you try re-stabbing your distributor? Sounds like you may be a tooth off.
A
aotrucker
  • Feb 8, 2016
I will try that in spring when I get it out again.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Feb 9, 2016
  • Feb 9, 2016
thats an old myth, no such thing as being off a tooth
http://www.stangnet.com/mustang-for...ly-be-one-tooth-off-lets-discuss-this.782429/
madspeed
Colonel Mustard
1,332
204
Feb 9, 2016
  • Feb 9, 2016
did you pullthe spout connector before checking your timing????
A
aotrucker
  • Feb 9, 2016
Yes I have everytime I time it
A
aotrucker
  • Feb 9, 2016
I have advanced my timing when I got the car before the trick flow top end kit and set it at 13 when I had my b303 cam. But 38 sounds ridiculous for a 5.0. I'm pretty sure my timing chain marks are lined up right
Farrell5.0
353
299
104
Vancouver, WA
Feb 9, 2016
  • Feb 9, 2016
Well I've had to re-stab mine a couple of times before because mine can't be spun 360 degrees. So in my case (and others'), it's fixed the timing issue. I guess I see how it technically can't be one tooth off, but if you can't spin the distributed 360* it's a pretty simple way to fix it.
A
aotrucker
  • Feb 9, 2016
I guess I should make sure it's on #1 in compression stroke as well? I havnt thought about that till now. Maybe that would make a difference?
madspeed
Colonel Mustard
1,332
204
Feb 11, 2016
#10
  • Feb 11, 2016
  • #10
Most definitely
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
  • Community Forums
  • The Welcome Wagon
