what size t/b and mass air do i need for a stock block and heads. the only thing that is done to the block is a e303. anything else i will need you guys could think of that i will need please let me know. thanks in advance!
qcrun98 said:I myself and ordering the Track Heat Intake for my stang. Tell me what you all think about the current mods and what kind of difference it will make. I plan on adding heads in the future so that is why I am getting the track heat now.
1. E303 Cam
2. Holley Fuel Pressure Regulator
3. Cold Air Intake
4. BBK Shorty Headers
5. Dynomax Exhaust soon to be Flowmaster with Dumps
6. 80mm BBK Mass Air Meter
7. 75mm BBK Throttle Body
8. 75mm BBK EGR Spacer
9. 3:73 Gears
Thank you any comments would be great. Also I read that some installs require a new aftermarket fuel rail, is this true because Summit Racing doesn't mention it anywhere on their site and they usually would if that were the case.
If you plan on getting a nice set of heads someday just throw on the track heat until then, no use wasting money down the road. If you are sticking with a light combo with say thumpers or gt40 heads I would go street heat.qcrun98 said:Would you guys suggest me to order the Street Heat instead of the Track Heat with my setup, is there that much difference I would feel between the 2? Please let me know what you would do as I am new to building a 5.0. Thank You so much.
