Farmers SN95 Member Jun 2, 2006 76 0 6 Ky Oct 22, 2007 #1 Oct 22, 2007 #1 I have a Trick Flow track heat upper intake for a 5.0, can I use that upper on the Trick Flow 351 lower (part # TFS-515L0004) on summit? or will just the R-series upper fit it?
ShortThrow50 Member Oct 22, 2006 923 2 16 Pa Oct 23, 2007 #2 Oct 23, 2007 #2 You should probably post this in 5.0 Tech section. Thats why you havent gotten any responses
85ragtop BTW, I like dudes. 10 Year Member Nov 29, 1999 823 475 123 NC Oct 23, 2007 #3 Oct 23, 2007 #3 Wrong place man. Thread moved.
samickguy15 Member Sep 1, 2005 404 0 16 Delavan, IL Oct 23, 2007 #4 Oct 23, 2007 #4 Check on Trick Flow's site. Chances are, if they will work, they share the same P/N.
samickguy15 Member Sep 1, 2005 404 0 16 Delavan, IL Oct 23, 2007 #5 Oct 23, 2007 #5 After looking, I'm pretty sure only the R-series upper will fit. You may want to e-mail or call Trick Flow.
