  • 1994 - 1995 Specific Tech
Trick Flow Twisted wedge heads
  • Thread starter Thread starter 94_5.0
  • Start date Start date May 23, 2004
9
94_5.0
337
Jacksonville, NC
May 23, 2004
  • May 23, 2004
I just bought a set of T/F T/W heads with 1.6 RR on them. I was wondering if I needed to notch my pistons with the setup that I have?
Does my cam (E-303) have to much lift or is it just fine?
Thanks in advance for all of the help.
C
CivicEater
579
  • May 23, 2004
Youll be fine. I belive the E-cam is about the same lift as the TF stage 1 and that one has plenty of clearance.
ponyboy19
1,640
May 24, 2004
  • May 24, 2004
never hurts to check but you'll be fine.
9
94_5.0
337
Jacksonville, NC
May 24, 2004
  • May 24, 2004
Hey civiceater what length push rods do I need with these heads?
ponyboy19
1,640
May 24, 2004
  • May 24, 2004
6.750 inch hardened push rod on 302ci base hydrolic roller motors
9
94_5.0
337
Jacksonville, NC
May 24, 2004
  • May 24, 2004
Sweet thanks ponyboy. now is it adviseable to change out the lifters as well? If so what should I get?
moneypit94
1,723
Macomb, IL
May 24, 2004
  • May 24, 2004
your lifters should be fine... Depends on how many miles you have on them... There are plenty of people running 170k+ on stock lifters. But then again with this added lift and spring pressure it couldn't hurt anything..
4Jenna
4,326
AZ
May 24, 2004
  • May 24, 2004
I also think you will be good, but I would def. check the p/v clearance on a cam swap to be sure. As for the lifters, I still run my stockers...and my stock pushrods.
So hows Hawaii treating you man?
Good Luck
Chris
ponyboy19
1,640
May 24, 2004
  • May 24, 2004
I know people who have the factory lifters that have been in several motors, Probably ok to leave them, I did in my last combination, but a new set of Ford Motorsport hydrolic roller lifters would hurt either. My friend did have a couple go bad.
Chris
just for clarification you must not have TFS heads if your using stock push rods.
4Jenna
4,326
AZ
May 24, 2004
#10
  • May 24, 2004
  • #10
Yup, I'm running Ebrocks...so disreguard.
9
94_5.0
337
Jacksonville, NC
May 27, 2004
#11
  • May 27, 2004
  • #11
Hey chris I am doing good and Hawaii is Hawaii...how is the ol'331 holding up? I see that you broke the 11 sec barrer, congrats.
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine 95 mustang Gt
  • Bett23
  • May 29, 2025
1994 - 1995 Specific Tech May 29, 2025
General karthief
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
