Trickflow Intake problem
THELAW1
12
I recently had a bucking and cold start problem, and after time and money and a full can of carb cleaner I found a vacuum leak coming from behind the distributor, the gasket that's between the lower intake and spacer it's a 1in spacer, I also notice the one of the front intake bolts have some how came loose and now won't retight, anyone have this problem and how did you fix it, I don't want to kick out 400.00 bucks for another intake...it's only leaking in between the 2 bolts
Sounds like it has to come apart. You'll need new upper gaskets and regarding your bolt not tightening down concern it sounds like your bolt or stud has stripped the threads on either the lower intake or the head. Time for a longer bolt and perhaps a helicoil kit.
