trickflow kit or engine swapout??
  • Thread starter Thread starter 1993whtstang
  • Start date Start date Apr 9, 2012
1993whtstang
146
Massachusetts
Apr 9, 2012
  • Apr 9, 2012
I am looking at modifying my engine power in my 1993 mustang gt. I was looking at getting the trickflow top end kit with the street burner intake. After I add everything up, trickflow kit, oil pan, water pump etc. it seems like for not to much more money i could get a crate drop in motor with the same horsepower? I have a friend who is a mechanic and does all my work to the car and he is the one that pointed out that his labor would be the same to do an engine swapout or a rebuild for me. What is everyones opinion? Also what engine and from where would you suggest I get it from. I am not looking for anything to crazy, just a fun weekend driver with an ocassional track run. Thinking maybe 400 hp? with the option to add a supercharger in the future. Any advice or opinions would be helpful.
Thank you
hoopty5.0
mechanicus terribilis
7,854
6,994
214
SW Houston
Apr 9, 2012
  • Apr 9, 2012
Top end kits are usually around $2k after you figure in gaskets, fluids, and other little nit picky stuff. With a good tune you could get around 325 flywheel horsepower (conservative estimate). That should be plenty of power to fit the "fun weekend driver" mold.
A crate engine would be much, much more, I'm sure everyone else here will agree.
foxbodymike87
739
35
39
Apr 9, 2012
  • Apr 9, 2012
thats one expensive kit or one cheap ass crate motor
Reactions: jdb3rd
cobra10494
206
22
29
North Jersey
Apr 9, 2012
  • Apr 9, 2012
LRS has the trick flow top end kit for $2400...Nice stuff for sure
jsw81
5 Year Member
Mar 19, 2007
307
71
68
IA
Apr 9, 2012
  • Apr 9, 2012
trick flow top end kit and do your own work
there is a great write up on this forum to do a head, cam, intake swap
your car will turn into feeling scary fast if your coming from a stock 5.0
Bryan83taco
554
40
39
SF Bay
Apr 10, 2012
  • Apr 10, 2012
I'm in the middle of my Trick Flow top end kit H/C/I swap. It's a great kit and comes with pretty much everything you need. I reccommend you buy new set of lifters & a water pump. Plus you will need at least 24 lb injectors, adjustable fuel pressure regulator, bigger fuel pump, 65 or 70mm throttle body. I'm sure there's more but that's all I can think of right now.
Gregg@TFS
Premium Sponsor
Feb 11, 2008
53
  • Apr 10, 2012
Your best bet is the 360 HP top end kit which will put you at about 300-310 at the wheels when complete. At that point you are still able to mount a supercharger later and add another 100-150 at the wheels pretty easily.
1993whtstang
146
Massachusetts
Apr 10, 2012
  • Apr 10, 2012
Thank you for all the information guys! i did not take into consideration I would still have to buy an intake ,fuel pump, throttle body and other stuff with a new engine. Im gonna contack Rick on here about a trickflow kit.
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
Looking for Real-World Experiences: VMP Gen3R 2.65L on 2011-2014 Mustang GT 5.0
  • STAT1C_5.0
  • Tuesday at 8:53 PM
2005 - 2014 S-197 Mustang -General/Talk- Tuesday at 8:53 PM
STAT1C_5.0
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
