trickflow
  • Thread starter Thread starter ms93gt
  • Start date Start date Jul 8, 2005
M
ms93gt
239
Bayville, NJ
Jul 8, 2005
  • Jul 8, 2005
Will trickflow heads on a high compression 306 with track heat intake and custom cam be able to run midd 11's? Would this combo be just as good as afr 165's, rpm intake and custom cam?
HardmanGT
500
Thomaston, CT
Jul 8, 2005
  • Jul 8, 2005
I think that the TF kit will get you into the very low 12's but not into the mid 11's like you want.
M
ms93gt
239
Bayville, NJ
Jul 8, 2005
  • Jul 8, 2005
It's not the kit though, custom cam is replacing the trick flow.
HardmanGT
500
Thomaston, CT
Jul 8, 2005
  • Jul 8, 2005
Custom cam only does so much more, I'm sure you could make more power that way, but my opinion is that 11's would require larger heads. I'm leaning towards 185 or more to get you to your goal
R
rowdie- stang
172
augusta ga
Jul 8, 2005
  • Jul 8, 2005
You can have as much power as you want but if you dont get it to the ground and hook it , it doesnt matter.
ninety15.0
1,336
  • Jul 8, 2005
sure it could...i think that combo will make enough power....you just need to focus on suspension, and traction...good luck
25thmustang
Mustang Master
Sep 5, 2003
2,021
85
99
Montgomery, NY
Jul 8, 2005
  • Jul 8, 2005
300 rwhp can go 11s with a good suspension and some good driving. To go solid mid 11s, Im going to say a street car will need 350 rwhp or so. I would say the TFS heads and track heat intake will go mid 11s on a higher compression 306. You might have to have the heads ported, but theres definately enough to do it. There are plenty of 300-325 rwhp TFS cars with stock bottem ends that a high compression motor and custom cam should make the power to go mid 11s. The right suspension some low 1.6 or high 1.5 60's and your in!
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jul 8, 2005
  • Jul 8, 2005
Speed-pro 306 pistons with 10.5:1 compression? 4 valve relief type? -2cc? That is what I have in the works, it only calculates to around 9.8:1 with TFS 61cc heads. You will be very limited to the cam choice due to piston to valve clearance with an inline piston on offset heads. I am pulling out the pistons if not selling the whole shortblock because of it.
M
ms93gt
239
Bayville, NJ
Jul 8, 2005
  • Jul 8, 2005
2 valve not 4. The part# on the piston read L2466F 30, but when I went to summit the only part # I found was L2488F 30. So maybe I misread wrong or something is fishy. The guy who I bought the motor from said he had 10:1 comp with edelbrock 61cc heads. I was gonna do some work to get the trickflows down to 58cc so it would be around 10:5.
M
ms93gt
239
Bayville, NJ
Jul 8, 2005
#10
  • Jul 8, 2005
  • #10
He also ran a trickflow sateg 2 cam and had no clearance issues so I think I might be good with a bigger cam.
stang5011
15
#11
  • Jul 8, 2005
  • #11
i am also running a 306ci with a trickflow efi manifold, stage 1 trickflow cam, tfs heads 61cc, 24lb injectors, 75mm throttle body, 1.6 rockers, keith black pistons 9.8:1, 190lph fuel pump, 373 gears. about what horsepower should i be in the range of and what whould i run in the 1/4 mile?
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
M
93 5.0 Microsquirt with Stage 3 trickflow tuning issues
  • marxpreston11
  • Jun 22, 2026
  • Digital Self-tuning Forum
  • 2 3 4
2K
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
9
Will I feel a difference
  • 90Stanger302
  • Mar 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Apr 13, 2026
