Trouble Code 12? fix?
  • Thread starter Thread starter jimilane
  • Start date Start date Nov 9, 2005
J
jimilane
158
Raleigh, N.C.
Nov 9, 2005
  • Nov 9, 2005
What do you do to fix a code 12.
I can't find anything.
Some stuff say the idle control motor.
I'll have to do more research.
Jim Lane
J
jimilane
158
Raleigh, N.C.
Nov 9, 2005
  • Nov 9, 2005
Ok, I think it's fixed.
I kept getting the code 12. The Actron CP9145 scantool that I was using couldn't run the tests because it couldn't control the rpm. This was caused by the IAC not working correctly.
I cleaned the IAC, then I was getting a code "0". It says it doens't know what the code is, but there is a problem. Anyway, I got a new IAC and took a look at it. It turns out that the spring in the old IAC was about worn out. The plunger on the old one was very easy to move compared to the new one. I then replaced the old IAC and the code went away and the engine idles a lot better.
I bet it starts right up tomorrow.
have a nice day and thanks for the help
Jim Lane
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
M
Bad PCM?
  • MrPuffels
  • Jul 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 22, 2026
MrPuffels
M
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
