  • SN95 4.6L Mustang Tech
Trouble on Re-start
  • Thread starter Thread starter BLKsteeda
  • Start date Start date Nov 2, 2007
BLKsteeda
236
Anywhere
Nov 2, 2007
  • Nov 2, 2007
I'm having a small problem with my car...it's an 01 GT, full bolt-ons, cams and ported heads. My car runs and idles perfectly, no issues at all except when the car is at temp and it get's shut off and upon re-starting it just constantly dies and will not idle normally unless I rev it pretty high for 10 seconds or so. Not sure why this would only be limited to re-starting. Any ideas?
chrisconsin
43
Washington
Nov 2, 2007
  • Nov 2, 2007
Have you upgraded your injectors?
BLKsteeda
236
Anywhere
Nov 4, 2007
  • Nov 4, 2007
No, I'm still running 19lb and have been for a while since the heads and cams were done, the tuner adjusted the fuel pressure in the tune for the injectors as the previous tune I had the car was running out of fuel at the top end....but, this problem with the car not restarting has only happened in the last couple of weeks.
jstreet0204
939
Winston Salem, NC
Nov 4, 2007
  • Nov 4, 2007
Are you able to datalog? If so get a log when the problem occurs and report back. Specifically you should be looking for loop state, tps voltage, o2 values, and fuel trims at idle. If you can get those values I as well as others can help you troubleshoot the problem.
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
