Trouble starting car, please help.
  • Thread starter Thread starter 1hot5.0
  • Start date Start date Mar 24, 2004
1hot5.0
1,615
Surprise, Arizona
Mar 24, 2004
  • Mar 24, 2004
About two times this past week, I went to start my car and the starter would keep turning over, even with no key in the ignition. Both times, I disconnected the positive battery cable and the problem was fixed.
Last night I went to start my car and it started really slow, however it did crank over.
I replaced my battery 3 weeks ago. Does this sound like it could be a loose ground wire on the starter or something?
Any replies would be greatly appreciated. Thanks!
ironmedic
1,361
Puyallup, WA
Mar 24, 2004
  • Mar 24, 2004
could be your starter solenoid or relay? try playing with the starter relay? or replace it?
bluebeast
215
Mass
Mar 24, 2004
  • Mar 24, 2004
this happened in my jeep it ended up being the starter. replaced that and it solved the problem.
1hot5.0
1,615
Surprise, Arizona
Mar 25, 2004
  • Mar 25, 2004
Ok thanks. Wow, this will be the cars third starter in two years.
HISSIN50
34
129
Mar 25, 2004
  • Mar 25, 2004
i would start at the solenoid and work downstream. if the solenoid cuts the juice when the key is shut off, no matter what is wrong with the starter itself, it will not have juice.
sounds like the solenoid is staying closed, either internally or from a bad ignition switch keeping juice to the solenoid trigger (much much less likely. it would take a neutral safety switch/clutch safety switch failure to assist that misfunction).
my two cents worth. good luck.
slowhatch82
583
NJ Pine Barrens
Mar 25, 2004
  • Mar 25, 2004
its not the starter!
my 82 did this to me! i changed the starter, and it worked for a few weeks and bammm, did it again...
change the starter solenoid, it runs between the battery and starter, there is a few other wires also...cant remember everything, its too early. the one that sits on the passenger side inner fender...thats where it was on the 82 anyways...fixed my problem right up.
goodluck, oh, its also alot cheaper than a starter!!
Chris
1hot5.0
1,615
Surprise, Arizona
Mar 25, 2004
  • Mar 25, 2004
Ok, thanks guys. I'll look into it... I need to get this car sold. I can't afford it with college right now.
1hot5.0
1,615
Surprise, Arizona
Mar 28, 2004
  • Mar 28, 2004
Out of curiosity, where is the starter relay located?
I have a new battery, replaced the soleniod about a year ago.... Im lost.
HISSIN50
34
129
Mar 29, 2004
  • Mar 29, 2004
solenoid is on the driver fender. look at the battery, then go toward the firewall. it may have a cover over it, some do and some are long gone.
it has two big lugs on it. one has one cable attached, the other has all sorts of stuff attached. and on top is a little wire that slides onto a stud. the solenoid is a little round deal.
good luck.
1hot5.0
1,615
Surprise, Arizona
Mar 29, 2004
#10
  • Mar 29, 2004
  • #10
Ok, thanks for the replies. I'm thinking of replacing the starter anyways since it is still under warranty. Is there any way I could replce it without removing the passenger header? I don't want to remove those headers after all the trouble I had putting them in.
1hot5.0
1,615
Surprise, Arizona
Mar 30, 2004
#11
  • Mar 30, 2004
  • #11
Just wanted to let you all know that I had the starter replaced by a local mustang performance shop. The problem is fixed. In addition, I got my money back on the starter from the auto parts store. Thanks again for all the help everyone.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
