trouble turning block by hand
  • Thread starter Thread starter yelbigbirdlow
  • Start date Start date Dec 26, 2007
Y
yelbigbirdlow
71
DFW Texas
Dec 26, 2007
  • Dec 26, 2007
im trying to install stud mount rockers. in doing so i am turning the block by hand with a 3/8 ratchet, brakerbar, 16mm socket, and a 12'' extention. so far i have broken 2 craftman ratchets( not inhalf but the ratchet startes to slip after i put so much presure on it) and a 1/2 to 3/8 adapter. i tried removing the plugs but the same thing happens. do i just need to use a 1/2 ratchet and socket??? what am i doing wrong?? HELP!!!!!!!!!!!!!!!!!!!!!!!!
dcurtis
688
Dec 27, 2007
  • Dec 27, 2007
First off, something is wrong if you cant turn it with the ratchet, definatly wrong if you have broken or stripped 2 craftsmans in doing so, unless by some stroke of luck you somehow ended up with 2 bum craftsman ratchets, which I doubt, is this a running engine still in the car, or is it on a stand, was it rebuilt? Oh yeah, if the engine is still in the car, and it is a standard tranny, it probably isn't turning because it is in gear and the engine is locked to the tranny by the clutch, try putting it in neutral and give it anouther try.
strtrcr50
Previously from Dirty Jerzey exit 7a
Dec 27, 2007
  • Dec 27, 2007
First off, use a half inch breaker bar. Second, pull the spark plugs. It'll turn over much easier then.
Disturbed90gt
portsmouth, va
Dec 27, 2007
  • Dec 27, 2007
i think hes tried that already
if its a rebuilt motor then something may be too tight
88mouse
630
Mooresville nc
Dec 27, 2007
  • Dec 27, 2007
Has the motor tried to turn at all? You may have one of the new rocker ran down to far.
cobra1923
68
Baltimore
Dec 27, 2007
  • Dec 27, 2007
I always used 1/2 ratchet, plugs in without too much problem. Maybe yank the belt off and start spinning accessories too. Maybe ones froze up.
Blandnuts
I don't swallow; I only swoosh
1,172
124
124
FloorDuh
Dec 27, 2007
  • Dec 27, 2007
Oh just a thought, it's out of gear right? (not that I would of ever ever done such a thing)
goodfastncheap
100
Bellevue, NE
Dec 27, 2007
  • Dec 27, 2007
New cam? Cam timing.
New heads/pistons? Valve clearance.
Will it turn CCW?
cobra1923
68
Baltimore
Dec 27, 2007
  • Dec 27, 2007
Good point, I'm guilty of that also.....
P
PJC Racing
199
#10
  • Dec 28, 2007
  • #10
take the car out of gear
Y
yelbigbirdlow
71
DFW Texas
Jan 19, 2008
#11
  • Jan 19, 2008
  • #11
timing chain gear was put on backwards and got caught on the cam thrust plate bolds not alowing anything to turn!!!! i relised my mistake when the thrust plate broke while using a 1/2'' ratchet!!!!!
Blandnuts
1,172
124
124
FloorDuh
Jan 20, 2008
#12
  • Jan 20, 2008
  • #12
Still better then running the engine and finding out that way .
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
M
67 Mustang Ignition Switch Wiring Diagram needed
  • Michaelell
  • Sep 14, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 3, 2026
Michaelell
M
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
