  • SN95 4.6L Mustang Tech
True/False
  • Thread starter Thread starter GoneMad96
  • Start date Start date Apr 10, 2004
GoneMad96
262
Cali
Apr 10, 2004
  • Apr 10, 2004
hey guys wondering if the stories are true about nos, does it really blow up motor as much as everyone says i thinking about adding it on my 96gt. And what is the difference between dry and wet shot??????
F
Flying5.0
18
  • Apr 10, 2004
It all depends on how your system is set up. The NOS systems out there today are as safe as any power adder you can buy. So I say false if you have it set up correctly.
F
Flying5.0
18
  • Apr 10, 2004
The difference between wet and dry, is that the dry system is sprayed in before the trottle body, and the wet system is sprayed in usually at the injectors, with a shot of gas mixed in with it.
GoneMad96
262
Cali
Apr 10, 2004
  • Apr 10, 2004
thanks man which is better between dry/wet????
F
Flying5.0
18
  • Apr 10, 2004
Both are pretty good, but when I get my nitrous, I will be going with the wet, as I feel you have less of a chance of leaning out, because you have fuel spraying with the nos.
GoneMad96
262
Cali
Apr 10, 2004
  • Apr 10, 2004
hmmm cool! is it super hard to install
F
Flying5.0
18
  • Apr 10, 2004
The dry system is probably easier to install that the wet. IMO
White Stang
467
Ft Lauderdale
Apr 10, 2004
  • Apr 10, 2004
Everything that creates alot of horsepower is going to cause stock parts to break especially engine internals. Everything in moderation unless you have deep pockets
70convert.302
CA
Apr 10, 2004
  • Apr 10, 2004
is it true that u have to upgrade to a bigger fuel pump after installing nitrous, my friend put it in his 98 into is cool air intake and it does not work. He told m that his dads friend told him to try a bigger fuel pump????
Bone Racing
1,075
Long Island, NY
Apr 10, 2004
#10
  • Apr 10, 2004
  • #10
dry - cheaper, easier to install then wet
wet - more efficent
both can be used safely if tuned and the proper safety measures are taken
70convert.302
CA
Apr 10, 2004
#11
  • Apr 10, 2004
  • #11
If the fuel pump does not work, anyone else have any ideas?
R
Ryan L
783
St. Augustine, FL
Apr 10, 2004
#12
  • Apr 10, 2004
  • #12
It's true that NOS blows up your motor, but NX does not.
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
P
rear Impact absorbers.
  • Praetorious
  • May 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2026
Praetorious
P
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
