trunk lid
  • Thread starter Thread starter stangguy93
  • Start date Start date Dec 21, 2004
stangguy93
10
  • Dec 21, 2004
hello guys, can you guys please help me figure this out, i have a 93 convertible and i would like to change the trunk lid, i have the luggage rack on it but i dont like it much, what is the easiest (and less costly) way to do this, should i go to the wreckers and get me one off a coupe that's not a convertible, if so would it fit without any modifications, thanks for any replies.
K
knowlegeable1
107
Cali
Dec 21, 2004
  • Dec 21, 2004
Im thinking bout doing the same. Straight swap?
5.0 Nostalgia
904
CT
Dec 21, 2004
  • Dec 21, 2004
My convertible came with a new trunk lid on it. The previous owner found it easier to just get a new one and paint it. It has a 94-98 Mustang spoiler on it and from the looks of it, the trunk is the same as the coupe trunk.
jb89coupe
416
CT
Dec 21, 2004
  • Dec 21, 2004
They're the same size but they mount differently. You'll have to drill some new holes and fill the old ones to use a coupe lid.
tonydalrymple
167
29
39
Salt Lake City, Utah
Dec 21, 2004
  • Dec 21, 2004
The conversion of a notch trunk lid to a 'vert is fairly easy; just time consuming because you do not want to drill holes in the wrong location. Only 6ea holes have to be drilled to use the notch lid on factory 'vert hinges. 4ea are for the small sheetmetal screws & two larger holes for the studs.
I removed the old lid, used the thin rubber gasket from between the lid & the hinge as a template, carefully measured to verify hole locations, & drilled.
The trunk lock from the origional lid needs to be transferred to the replacement lid. It's actually going to be the biggest "pain" if you've never changed one out before. You will need to drill out the obvious aluminum pop rivet; inside the lid, right under the lock assembly, between the two little clear license plate light lenses. I'm sorry; I cannot describe removal step by step too you. I can tell you that if you look carefully; it is not too hard to figure out with patience, a pair of needle nose pliers, & a screwdriver or two. Good luck!
stangguy93
10
  • Dec 22, 2004
thank you very much tony for your help, you guys are great, thanks.
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Dec 22, 2004
  • Dec 22, 2004
Another option, if you can't find a decent coupe lid, is www.blueovalindustries.com They sell a steel deck lid for $155. I paid $100 for a used coupe lid 5 years ago from a wrecking yard when I did my car.
artus70
72
  • Dec 22, 2004
Is it really that bad to just bondo in the small holes??? It just took me minutes to pull off the rack....used a small hammer to push the holes down and block sanded since the lid is very flat to start with plus half of them are under the spoiler anyway. Is it going to give me problems later on????
tonydalrymple
167
29
39
Dec 22, 2004
  • Dec 22, 2004
Not a good idea really if you think about it. You do not have anything under the bondo to support it\keep it from moving. You open & shut the trunk enough times; hit potholes on the road that jar the chassis\body....
If you're lucky; you will only see cracking around the outer edges of the bondo in the paint. Unlucky; the whole wad of bondo pops out along with the paint on top of it. kinda looks neat though; like someone shot your car many times in the trunk with a 44 magnum! (Yes, I've seen several lids done with bondo before)
Proper repair will cost more than just getting another "lid" unless you can weld, body work, & paint.
LX Rear Trunk Lid Emblem Install Measurements
  • Habu135
  • Oct 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2025
Habu135
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Long time lurker.
  • Stlmikie
  • Mar 22, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2026
Stlmikie
J
95 Cobra Trunks
  • Jeff R
  • Apr 17, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 17, 2025
Chythar
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
