Trunk lights wont turn on...
L33T MinGrey GT
51
When I hit the breaks, the break lights do turn on, but the lights in the top of the trunk wont. I checked the bulbs and they are fine.
One thing I gotta tell yall is that my ABS was replaced and that the Power Box (the one by the driver side, behind the battery) was replaced in the process. SO Im looking for a fuse not plugged in right or missing or messed up. Do any of you guys by any chance know the location of this fuse?
It will be great just to go to that specific fuse and check it out. There are bunch of these that are empty, all you see is the hole.
Any help will be greatly appreciated.
TIA!
The left, right, and center brake lights all share the same fuse. That leaves only two possibilities I can think of:
(1) bad ground (black wire) to the center light assembly;
(2) broken wire between the brake pedal switch and center light (wire color is dark green).
