stang9gt Founding Member Dec 21, 2001 1,247 0 0 State College, Pa Sep 21, 2004 #1 Sep 21, 2004 #1 I tried to put the motor in with the trans and long tubes attached...Not going to happen for me at least...I took the driver side long tube off (cause that one is easy to install with motor in car) and it went right in....
jastang Founding Member Nov 21, 2000 947 1 18 Little Elm, TX Sep 21, 2004 #2 Sep 21, 2004 #2 Did you get the other one in? Did you have the steering shaft disconnected or anything?
T tarch My 8V > 4V > 2V Founding Member Aug 20, 2002 3,073 1 56 Redmond, WA Sep 22, 2004 #3 Sep 22, 2004 #3 awesome!
stang9gt Founding Member Dec 21, 2001 1,247 0 0 State College, Pa Sep 22, 2004 #4 Sep 22, 2004 #4 jastang said: Did you get the other one in? Did you have the steering shaft disconnected or anything? Click to expand... Steering shaft was out of the way...I just sat the other header down in there before sitting the motor in....
mogs01gt Founding Member Jul 22, 2002 3,113 30 119 Ohio Sep 22, 2004 #5 Sep 22, 2004 #5 Did you remove the radiator?
stang9gt Founding Member Dec 21, 2001 1,247 0 0 State College, Pa Sep 22, 2004 #6 Sep 22, 2004 #6 mogs01gt said: Did you remove the radiator? Click to expand... \ Everything that needed to be out of the way was...The Mac lt's just wouldn't get around/over the motor mount supports...
