trying to ID tranny bolt pattern
I have a lakewood blowproof bellhousing laying here that I picked up from a Ford widow :-(
I bought it unknowing.He used to race all types of Fords through the years. it came from a small block but I have no idea what tranny bolts to it.
when you are looking at the tranny bolt pattern.
the distance between the two bolt holes on the vertical plane,(up & down) is 6-1/4" on either set.
The distance between the bolt holes on the horizontal plane,(side to side) on the one set is also 6-1/4" on one pair and the other pair 7-7/8". you can clearly see the offset on the one bolt hole.
The center hole is 4-7/8" diameter.
If you know this is NOT for a T5 then even that is a help to me. Then
ask some of the 'older' ford stickshift men in the house if they recognize it.
thanx for any help, DAVE
